System Security and I/NET Seven
  • System Security and I/NET Seven
  • Chris_Asbury
    Chris_Asbury
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 01:30 PM
What functions can you do in I/NET if you change the Windows users rights?
All versions of I/NET Seven Software
Changing the Windows users rights affects the way I/NET functions.
  User Account
I/NET Seven Operation Administrator Power User User
Install I/NET Yes Yes No
Remove I/NET Yes Yes No
Upgrade I/NET Yes Yes No
I/NET Configuration Yes Yes Yes
DBCreate Functions
Create db Yes Yes Yes
Import I/NET 2X Yes Yes Yes
Verify existing db Yes Yes Yes
Remove existing db Yes Yes Yes
Backup db Yes Yes Yes
Restore db Yes No No
Import Docutrend Archive Yes Yes Yes
Upgrade db Yes Yes Yes
Seven Reports
View Yes Yes Yes
Run Yes Yes Yes
Configure Yes Yes Yes
Save Yes Yes Yes
Print Report Yes Yes Yes
Mount Archive Yes Yes Yes
View Archive Yes Yes Yes
Run Archive Yes Yes Yes
Print Archive Report Yes Yes Yes
Archive Configuration
Event Archive Configuration Yes Yes Yes
Run Yes Yes Yes
Trend Archive Configuration Yes Yes Yes
Run Yes Yes Yes
View Yes Yes Yes
I/O Server Configuration
Promote Filemaster Yes No No
Demote Filemaster Yes No No
Promote Client Yes No No
Demote Client Yes No No
There are two components of security available to users of I/NET Seven: I/NET Seven passwords and Microsoft Windows user accounts. I/NET Seven passwords are specifically aimed at limiting a user’s access to features and functions within the I/NET Seven system. The restrictions imposed by I/NET Seven passwords are application-specific (i.e., they only affect the I/NET Seven system) and do not provide a replacement for domain security methods.
Microsoft is very clear about the importance of limiting permissions to users in a network environment. The user account permissions that are standard in Windows 2000 and Windows XP allow full management of the computer to users with “Administrative” group membership or any group containing administrative permissions. The “Power User” group permissions allow users to install programs but restrict what these users can do to the operating system. The “User” group is the most secure because its operators cannot modify operating system settings or other users’ data. Microsoft clearly states that operators assigned to the User group may have trouble running legacy programs. This should pose no problem for I/NET users since I/NET Seven has been specifically developed to run on the Windows 2000 and XP operating system.
Most functions of I/NET Seven including general system operation, AMT (alarms, messages, and transaction) processing, reporting (Seven Reports), and archiving are available to an operator assigned to the User group or any group with those permissions. However, these operators cannot install I/NET Seven or delete or upgrade its database. Seven Reports is password-protected but can be configured within I/NET Seven to allow automatic logon to operators of a Host PC.
The above spreadsheet shows the functions/operations that can be performed by members of the Administrator, Power User, and User groups.
For further information about Windows security, please refer to Microsoft Windows online help for more information about user accounts, permissions, and Microsoft Management Console best practices". https://docs.microsoft.com/en-us/previous-versions/tn-archive/cc750076(v=technet.10)
  • TAC INET
Tags (2)
  • 5932
  • inet
