Syntax error, unexpected token 'xxxxx' compiling PE program.
  • Syntax error, unexpected token 'xxxxx' compiling PE program.
‎2018-09-10 12:25 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:05 AM
PE program will not compile, due to the following error:
Cyberstation
All Andover Continuum controllers
Program is using one or more reserved keywords
Remove reserved keywords from program's code.
See Andover Plain English Language Reference Guide appendix B for a list of reserved keywords.
Tags (2)
  • 5683
  • plainenglishlanguagereference
0% helpful (0/1)
