Sync LED on FOI still on after correcting the line fault on the output of the CRR.
  • Sync LED on FOI still on after correcting the line fault on the output of the CRR.
‎2018-09-06 03:26 PM
I never reset the "Sync" LED on the FOI after I corrected the line fault on the output of the CRR. Will this cause any communication problems?
I/NET
CRR
Line Fault
  1. Reset the sync LED
  2. If you can NOT extinguish the Sync LED you should find the fault.
  3. Leaving this light “on” does not cause communication problems.
  • TAC INET
  • 1116
