Suprema Fingerprint Reader Integration
  • Suprema Fingerprint Reader Integration
‎2018-09-10 10:24 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:05 AM
EcoStruxure Security Expert
  • Security Expert
Security Expert integrates with Suprema BioEntry, BioEntry Plus, and FaceStation devices. Enrolment is both quick and easy with users scanning their fingerprint or face at an enrolment reader.
The Suprema reader uses the scanned data to create a credential template, including a card number, which it sends to the Security Expert Server. Security Expert then sends this template to any other Suprema readers that are attached to the system so that only one enrolment is required.
The following information is available on integrating Suprema Fingerprint Readers with Security Expert
  1. A list of qualified Suprema devices and configuration details can be found in the Suprema Biometric Integration in Security Expert Application Note.
  2. There are some available help topics in the online help. In the Security Expert  Client go to ABOUT | HELP and search for "Biometric Readers" and "Suprema".
  3. Each Suprema reader requires a wiegand port on a controller / expander, a license (SX-BIO-SP) and an IP address. The amount of Suprema readers allowed is only limited by these numbers.
  • EcoStruxure Security Expert
Tags (2)
  • 19491
  • AdamSteele24
100% helpful (1/1)
