Supported BACnet Variable Objects and Properties for Alarm Monitoring
  • Supported BACnet Variable Objects and Properties for Alarm Monitoring
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-22 07:24 PM
on ‎2025-10-22 07:24 PM
When configuring BACnet alarms in EcoStruxure Building Operation (EBO), users may encounter a potentially misleading message in the Monitored Variable description:
Monitored variable: Choose the method for referencing the property that you want to monitor. Select System reference to define a path-based reference to an object or property that is currently located on the EcoStruxure BMS server.
While technically correct, this statement may cause confusion. It suggests that any object or property on the EBO server can be used as a monitored variable for BACnet alarms. However, only specific BACnet objects and properties are supported for each alarm type.
  • EcoStruxture Building Workstation
  • Bacnet
  • Alarms
The ambiguity arises from the assumption that all BACnet objects and properties are valid for alarm monitoring. In reality, only a subset is supported depending on the alarm type. Misconfiguration can lead to unexpected behavior or non-functional alarms.
To ensure proper configuration, refer to the table below for supported combinations of BACnet objects and properties for each alarm type:
Alarm Type Monitored Variable Object Monitored Variable Property
Change of State BACnet Digital Input Value
BACnet Digital Output Value
BACnet Digital Value Value
BACnet Multistate Input Value
BACnet Multistate Output Value
BACnet Multistate Value Value
Change of Value BACnet Analog Input Value
BACnet Analog Output Value
BACnet Analog Value Value
Floating Limit BACnet Analog Input Value
Floating Limit Setpoint Reference BACnet Analog Input Value
BACnet Loop Setpoint
Out of Range BACnet Analog Input Value
Buffer Ready BACnet Trend Log (Any) —
Additional Reference
For more details, see:
🔗 BACnet Alarm Types and Monitored Variables Table
  • KatharineVasquez25
