Sunrise/Sunset does not function correctly in I/NET Seven rev 2.16
  • Sunrise/Sunset does not function correctly in I/NET Seven rev 2.16
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 02:01 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-02 06:31 AM
  • Sunrise/Sunset does function correctly in I/NET Seven rev 2.16
  • Sunrise/Sunset workaround in I/NET Seven 2.16
TAC INET
Currently there are some issues with Sunrise and Sunset working correctly in I/NET Seven rev 2.16. The follow steps are given as a work around to solve these issues.
There are two different ways to make this work correctly:
  1. Add some starts between the Sunrise and Sunset.
    It is important that these starts do not have any days of the week defined.
  2. Use a Cycle between the Sunrise and Sunset.
    It is important that this Cycle does not have any days of the week defined.
  • TAC INET
Tags (2)
  • 3487
  • inet
