Suggested replacement for a TS-5751-850 (low temperature application)
  • Suggested replacement for a TS-5751-850 (low temperature application)
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 09:10 AM
Existing sensor has failed (TS-5751-850).  The application involves below freezing temperatures (not outside air but a storage freezer).  Since the sensor is obsolete, what's a suggested replacement?
Network 8000 MicroZone II
Sensor failure
Try the TO series sensor from Veris Industries.
Labels (2)
  • Field Devices
  • TAC IA Series
  • 16890
