Standard Applications for I/A Series Micronet BACnet (MNB) controllers
  • Standard Applications for I/A Series Micronet BACnet (MNB) controllers
‎2018-09-10 12:30 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:04 AM
I/A Series
  • I/A Series WorkPlace Tech 5.x and above
  • I/A Series MNB controllers
A library of standard pre-engineered applications for MNB controllers is available. These can be modified and used as a reference for creating MNB applications.
The library of standard applications can be downloaded from Exchange Extranet. Below is a list of the applications available for downloads.
  • DUI Application Stencil Operation Guide
  • Application Objects Visio Stencil (Includes DUI_App)
  • Applications - BACnet Zone, VAV, and Unitary Applications using SP and SPP
  • Momentary Start/Stop Object Application Operation Guide
  • Application - BACnet Zone Controller Applications
  • Application - BACnet VAV Box Applications
  • Application - BACnet Unitary Applications
  • Stencil - Application Stencils
  • Application - VAV_Staged_Heat.vst
  • Application - FC_1DX_1EH.vst
  • Application - FC_1PropCL_1PropHT.vst
  • Application - FC_2Pipe_2PosHC_wCO.vst
  • Application - All BACnet Unitary Applications.zip
  • Application - All BACnet VAV Box Applications.zip
  • Application - VAV_Cooling_Only.vst
  • Application - VAV_Floating_Heat.vst
  • Application - AHU_HeatPump.vst
  • Application - VAV_Parallel_Fan_Staged_Heat.vst
  • Application - VAV_Parallel_Fan_Floating_Heat.vst
  • TAC IA Series
Tags (2)
  • 10890
  • RyanSuar19
100% helpful (1/1)
