Software administrator - message: No Driver Module for path:
  • Software administrator - message: No Driver Module for path:
  • sesa150561
    sesa150561
‎2018-09-06 10:44 AM
  • No Driver Module for path
  • StruxureWare Building Operation
Have some errors about No Driver Module for path*
In principle it means that we have a mount point but no driver. It could potentially happen if we have an object on another server referring those points.
For example:  The messages are relating to broken binds of monitored values in trend logs.
i.e. The original binds were changed to relative binds, and after that the monitored values were moved to another folder. In this case correct the bindings would remove the messages
  • 12244
