Smoke Sensor Calibration Error
Select a Country
  • Smoke Sensor Calibration Error
  • Sandeep_Kumar006
    Sandeep_Kumar006
Sandeep_Kumar006 Troubleshooter
‎2025-06-23 05:50 PM
Last Updated: CraigEl Champion ‎2025-06-23 05:51 PM
  1. Issue
Panel showing detector Calibration error.
ESMI Fire Detection.
  • FFSULH1001.
  • FFSULH1002.
When the contamination increases significantly and exceeds the sensitivity range for the smoke sensor, it is no longer able to perform calibration, causing a calibration error.
  1. Understanding the Calibration Process:
    • The Esmi Ultima panel performs daily calibration and drift compensation for all addressable smoke sensors at 7 AM by default.
  2. Sensitivity and Contamination:
    • Over time, dust and other contaminants can build up in the chamber of a smoke sensor, increasing its sensitivity.
    • Illustration:
      • Left Image: Clean sensor requiring 2.0% per foot of smoke to activate the fire alarm.
        Right Image: Contaminated sensor with increased sensitivity, requiring less smoke to reach the alarm threshold of 2.0% per foot.
  3. Trouble Condition:
    • When the panel can no longer compensate for the contamination, it indicates a trouble condition.
    • The Esmi Ultima panels can compensate for contamination build-up in addressable smoke detectors and addressable multi-criteria detectors.
    • Daily calibration offsets any contamination, ensuring each smoke detector remains within its UL Listed sensitivity range.
  4. Recommended Action:
    • Clean or replace the sensor with a new one of the same model. If you have a replacement in stock, replace it immediately.
  • ESMI Fire Detection
  • SandeepKumar25
