SmartConnector RESTful gateway returns error "Container Id not found"
  • SmartConnector RESTful gateway returns error "Container Id not found"
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2024-10-07 06:14 AM
on ‎2024-10-07 06:14 AM
In Swagger user can login but can't get the id of the root container. Below response is received:
"Message": "Container Id not found""Message": "Container Id not found"
SmartConnector
EBO user password need to be changed due to Password Expiry configured in the password policy. When user tries to login to WorkStation or WebStation, below change password dialog will be recieved.
Make sure to change the user password before reaching the limit the days configured in the Password Policy. Password expiry can also be reconfigured to change number of days or disabled if not needed, refer to Configuring the Password Policy using WorkStation or Configuring the Password Policy using WebStation
  • MahmoudSayed24
