Smart Sensor will not display room temperature using a simple program on B3 controllers
  • Smart Sensor will not display room temperature using a simple program on B3 controllers
  • sesa115924
    sesa115924
‎2018-09-06 09:27 AM
Configuring a Smart Sensor in a B3 controller in StruxureWare Building Operation using a simple script program to display temperature. The temperature does not display in the Smart Sensor LCD.
Automation Server with B3 controllers
SmartStruxure 1.4 attaches a _AV, _BI, etc. to the BACnet name
  1. Remove the _AV, _BI, etc. from the LCDDisplay BACnet name
  2. Download the controller again
  3. The display functions as suggested
Tags (2)
  • 16661
  • namelcddisplay
