Smart Sensor Availability / Obsolescence
  • Smart Sensor Availability / Obsolescence
‎2018-09-11 01:28 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:59 AM
What TTS-SD-LED and TTS-SD-LCD Smart Sensors are available?
TTS-SD-LED Series
• TTS-SD-LED-1
• TTS-SD-LED-B-1
TTS-SD-LCD-Series
• TTS-SD-LCD-1
• TTS-SD-LCD-4-2
• TTS-SD-LCD-B-1
• TTS-SD-LCD-C-1-10P
• TTS-SD-INFBUF
Some products in this range have become obsolete due to the discontinuation of some key components.
Full details are on the attached Product Announcement PA-00171
TTS-SD-LED-1 Discontinued
TTS-SD-LED-B-1 Discontinued
TTS-SD-LCD-1 Modified
TTS-SD-LCD-4-2 Modified
TTS-SD-LCD-B-1 Replaced by TTS-SD-LCD-1
TTS-SD-LCD-C-1-10P Discontinued
TTS-SD-INFBUF Discontinued
Labels (2)
  • Field Devices
  • 13158
