Single I/NET Seven Report will not print
  • Single I/NET Seven Report will not print
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 11:57 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-12 07:14 AM
A Seven Report will not print; however, most of the other reports print just fine. What is wrong with this single report?
TAC INET
I/NET Seven Site
Share options on the defined default printer are preventing the reports from being printed.
Steps to change the Printer properties On an Windows XP PC so it will print I/NET Seven Reports:
  1. Go to the following location: Windows Start Button > Settings > Printers and Fax Section
  2. Right click on the Default Printer and choose Sharing...
  3. Choose the Share this Printer option. The Printer name and other information will appear by itself after you choose the Share option.
  4. Select the Apply button
This should allow the Seven reports to print.
  • TAC INET
  • 1854
