SigmaX reports a missing DLL
  • SigmaX reports a missing DLL
  • DavidChild
    DavidChild
  • sesa119747
    sesa119747
  • Gary
    Gary
‎2018-09-06 02:40 PM
Last Updated: Sisko DavidChild Sisko ‎2021-05-13 06:22 AM
After installing SigmaX version 5.0 or later, when running the software an error message reports a missing DLL.
Satchwell Sigma
SigmaX version 5.0x, 6.0x and 7.0x
System Path variable is missing C:\Sigma\Bin in Environment Variables
Make the following modification to the PC's System Properties. Note: This addition is only required on machines running SigmaX.
For Windows XP and Windows 7
  1. Right click the My Computer icon on the desktop and select Properties
  2. Choose the Advanced tab and select the Environment Variables button
  3. From the System Variables section, highlight Path and select Edit
  4. The statement ‘;C:\Sigma\Bin’ must be added to the end of the Variable value line
For Windows 10
  1. In the search bar type and type 'environment' and go to 'edit the System Enviroment Variables'
  2. Bottom right go to Enviroment Variables
  3. In the bottom window 'System variables', find 'Path' and double click
  4. In the 'Edit environment variable pane - create a 'New' variable and add in c:\sigma\bin
  • Satchwell BAS & Sigma
Tags (2)
  • 3315
  • DavidChild21
50% helpful (1/2)
