Sigma remote client software has been added to new PC and the client will not connect to the Sigma server properly.
  • Sigma remote client software has been added to new PC and the client will not connect to the Sigma server properly.
  • CraigEl
    CraigEl
‎2018-09-06 02:42 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 08:04 PM
Sigma remote client software has been added to a new PC, but the client fails to connect reliably to the Sigma server.
On some occasions, the connection is established, but the Sigma Client Menu options are unavailable.
Satchwell BAS & Sigma
Sigma remote client (up to version 4.04)
Sigma software versions up to 4.04 rely on Windows File Sharing to enable remote client connections to the Sigma server.
This dependency can fail due to misconfigured network settings, firewall restrictions, or incompatible Windows configurations.
Recommended Solution
  • Upgrade to Sigma version 4.05 or later, which eliminates the dependency on Windows File Sharing for remote client connections.
Alternative Workarounds (if upgrade is not possible):
  • 2.1. Ensure file sharing is enabled between the Sigma server and client PCs by using a common Windows username and password across all machines.
  • Verify that the firewall and network settings allow TCP port 3614 to pass through. Unblock this port if necessary.
  • If the PCs are part of a client-managed network, consult with the site's IT team to ensure TCP port 3614 is permitted through routers and firewalls.
  • If Sigma communication must traverse a firewall, ensure UDP port 49152 is unblocked.
  • Satchwell BAS & Sigma
Tags (2)
  • 3268
  • CraigEllis25
