Sigma Transition - duplicated SFE graphics but in a different language.
  • Sigma Transition - duplicated SFE graphics but in a different language.
  • DavidChild
    DavidChild
‎2020-12-07 01:49 AM
on ‎2020-12-07 01:49 AM
Duplicated SFE Short Form Edit graphics
  • Sigma
A duplicated set of Short Form Edit graphics are created but are in a different language appear along side the original SFE graphics when using Data Import with a Sigma transition into EBO
The example below shows the original DataImport was completed in English, the second DataImport was completed in Danish.
Before a Sigma DataImport is undertaken, ensure that the correct language is set in EBO.
Delete the Sigma Interface, set the correct language and start the transition again.
Note: By deleting the Sigma Interface, this will delete all the SFE graphic links on the objects and a clean set of SFE graphics will be created on all the objects.
Labels (2)
  • Satchwell BAS & Sigma
Tags (2)
  • 19500
  • DavidChild20
