Continue
  • My Subscriptions
  • Events
Sigma Server crashes and the hard drive has filled with archived Alarm Logs.
  • Sigma Server crashes and the hard drive has filled with archived Alarm Logs.
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • DavidChild
    DavidChild
‎2018-09-10 11:26 PM
Last Updated: CraigEl Champion ‎2025-10-21 09:28 PM
Sigma Server crashes, and the hard drive becomes full due to an accumulation of archived Alarm Logs, all timestamped around the same time. Alarm Fail Safe window displays:
  • "Logging Database is 100% full"
  • "Unable to archive"
Satchwell BAS & Sigma
Satchwell Sigma
The Sigma Server crashes because the Logging Database is full. Normally, this database is automatically archived. However, if the folder C:\Sigma\Data\ArchivedLogs is missing, the archiving process fails repeatedly. Each failed attempt generates a System Message, which further fills the Alarm Log Database, triggering another archiving attempt—creating a loop that eventually crashes the server.
Step 1: Recreate Missing Folders
Ensure the following folders exist under C:\Sigma\Data. If not, manually recreate them:
  • ArchivedAlarms
  • ArchivedLogs
  • ArchivedTransactions
Step 2: Test Archiving Functionality
  1. Create an Action and Schedule to archive the logs.
  2. Allow the schedule to run.
  3. Verify that a file named Sigma0nnnn.dbs appears in the ArchivedLogs folder.
✅ If successful, you may either remove the daily schedule or leave it in place for ongoing archiving.
  • Satchwell BAS & Sigma
Tags (2)
  • 12312
  • CraigEllis25
