Sigma IC Lon Values going on and offline
  • Sigma IC Lon Values going on and offline
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2022-09-23 07:48 PM
on ‎2022-09-23 07:48 PM
Troubleshooting Sigma IC LON Values going on and offline
Satchwell Sigma
  • Sigma Release 4_05-SEB (Build 3_43_18)
  • Sigma Release 4_05-SP2 (Build 3_42_48)
  • Sigma Release 4_06 (Build 3_44_14)
  • Sigma Release 4_06 SP1 (Build 3_44_16)
  • Sigma Release 4_07 (Build 3_45_48)
  • Sigma Release 4_07-SP1 (Build 3_45_51)
  • Sigma Release 4_07-SP2 (Build 3_45_58)
  • Sigma Release 4_08 (Build 3_46_57)
  • IC LON
Lon Values going into and out of default
  • Compare the IC-LON’s Receive heartbeat set in the “gateway.txt” file in the IC-LON controller, to the send heartbeat set in the controller.
    The recommendation is for the receive heartbeat be set to 2-5 times the send heartbeat of the field controller.
    Starting at 2 times, then increasing if the problem persists.
  • If the controller doesn’t have a heartbeat and the LON value rarely changes, disable the receiver heartbeat in the IC-LON’s gateway.txt file by setting the heartbeat to 0.
Example:
1     2     3        4      5   6  7
2,   2,  112,  1293,  0,  0, 0
The Sigma system is now out of its support period, consideration should be given to transitioning or upgrading to
SpaceLogic - EcoStruxure Building Operation.
  • Satchwell BAS & Sigma
  • GaryMontague22
