Sigma ARCNET Cable Requirements
  • Sigma ARCNET Cable Requirements
  • sesa119747
    sesa119747
  • DavidChild
    DavidChild
‎2018-09-07 07:54 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-10-04 07:21 AM
ARCNET Cable Requirements.
Satchwell Sigma
  • Sigma 4.05 and earlier versions
  • V53 and ARM7 Processor Boards
Sigma ARCNET Network cabling advice.
The following Sigma Cabling Guide should be followed when installing an ARCNET network for Sigma:
  • Sigma Cabling Guide 2.2
Network biasing and earthing arrangements will be required and further information about cabling can be found in the following guides:
  • For V53 Processor Boards (UNC496, 596, UNC532, DNN and IC integration controllers): Sigma Configuration Guide - Chapter 26a
  • For ARM7 Processor Boards (UNC696, 796 & UNC632): Sigma Configuration Guide - Chapter 32; Sigma Configuration Guide - Chapter 31
  • For ARM7 Processor Boards (DNN3 Decentralised Network Node): Sigma Configuration Guide - Chapter 33
  • For ARM7 Processor Boards (IC3 Integration Controller): Sigma Configuration Guide - Chapter 34
  • Satchwell BAS & Sigma
  • 4466
