Showing all points in the StruxureWare Database.
  • Showing all points in the StruxureWare Database.
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 09:47 AM
Enterprise Server
Automation Server
In some instances you may need a complete list of I/O or values on a site.
This process will show you the majority of objects on the system. It is possible that some will not be listed.
  1. For EACH Server on the system.
  2. In the System Tree Pane, expand the System Folder
  3. Expand to the Modules/RuntimeDBManager/VariableManager folder
  4. Click on the Variables Folder
  5. Copy the Contents to an Excel Document and repeat for each AS on the system.
  • 15258
