Showing Outdoor air temperature on STR350
  • Showing Outdoor air temperature on STR350
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 10:29 AM
How to show the Outdoor temperature on STR350?
STR350
By the use of the variable nviOutdoorTemp, it is possible to show the outdoor temperature on the STR350 device.
The outdoor temperature will be shown when you press the selection button.
Make a binding for the outdoor temperature to the variable nviOutdoorTemp on the STR350 device.
  • 12998
