Should changes be made to configuration profiles in a stable I/NET network?
  • Should changes be made to configuration profiles in a stable I/NET network?
‎2018-09-07 12:11 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:59 AM
Is it OK to change configuration profiles in a stable I/NET network?
I/NET network
In accordance with TCON 209, there may be differences in the routing data for each configuration profile.
You should not change configuration profiles in a stable I/NET network. (TCON 209, 1-10)
  • TAC INET
  • 1418
