SevenTrends custom report - portions of the printed report are blank
  • SevenTrends custom report - portions of the printed report are blank
‎2018-09-06 03:21 PM
SevenTrends Report
The links between your database tables may not be correct or you may be sorting the wrong tables.
  1. The links between your database tables may not be correct. Check your links.
  2. You may be sorting the wrong tables. Make sure you are sorting the tables that have the correct information.
  • TAC INET
  • 1331
