Setup Tap emulation on the HHC
  • Setup Tap emulation on the HHC
  • LeeCravens
    LeeCravens
‎2018-09-06 03:29 PM
What code do I use on the HHC to set the Tap emulation?
Handheld Console
Setup Tap emulation.
To set up Tap emulation:
  1. Press code 90
  2. Press [ENTER]
  3. Press the [INC] or [DEC] to toggle through 78010, 78035 or 78061 Tap emulation.
To set the baud rate for Tap emulation:
  1. Press code 91
  2. Press [ENTER]
  3. Press the [INC] or [DEC] to toggle through the available PC port baud rates. The baud rate is typically 9600 if connected to a host PC.
Refer to the appropriate controller TCON for more information.
  • TAC INET
  • 972
