Setup External Log Storage using AVEVA PI system
Select a Country
  • Setup External Log Storage using AVEVA PI system
  • PeterEdvik
    PeterEdvik
  • Mahmoud_Sayed
    Mahmoud_Sayed
Mahmoud_Sayed Champion
‎2023-08-08 12:11 AM
How to configure the EcoStruxure BMS External Log Storage feature using PI System.
  • Building Operation Enterprise Central
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server
Need EBO to send selected trend logs and the event log to AVEVA PI System directly without the need for intermediate storage or specialized PI System connectors.
The following video will illustrate how to:
  • Install and configure AVEVA PI system (PI Server and PI Web API) for testing.
  • Configure PI system settings in EBO.
  • Configure trend logs to be written to PI system.
  • View and organized the data in PI system Explorer.
Things you need:
  • EBO 2023 (V5.0.3) or higher with valid AVEVA PI System connection license or demo license (Enterprise Server, AS-P, AS-B or Edge Server).
  • AVEVA PI server and PI web API with valid license (Check EBO Information Technology System Planning Guide for tested versions).
  • For more information about PI system recommended architectures, system requirements and installation instructions, please check AVEVA documentation, PI System™ | AVEVA, OSIsoft - PI System and YouTube video published by AVEVA for detailed instructions about installing and setting up PI system Setting up a PI System Development Environment From Scratch - YouTube
Note: In EBO V7.0.1 or higher, values can also be read and hosted from an AVEVA PI System, refer to: Hosting Points from AVEVA PI System
Note: Starting with EBO version 7.1.2 and later, disabling the "EnableCSRFDefense" setting on the AVEVA side is neither required nor recommended. Hotfixes are available for EBO 6.0.4 and EBO 7.0.3. Please contact Technical Support to obtain the appropriate hotfix. Refer to: EBO cannot connect to AVEVA PI when EnableCSRFDefense is enabled - Schneider Electric Community
Tags (3)
  • MahmoudSayed23
  • MahmoudSayed25
  • MahmoudSayed26
100% helpful (3/3)
