Settings for the USRobotics 5686 series for use with a DMS panel.
  • Settings for the USRobotics 5686 series for use with a DMS panel.
  • sesa119747
    sesa119747
  • sesa116877
    sesa116877
‎2018-09-07 02:04 AM
  • USRobotics 5686 series
  • DMS panel
For the modems to communicate, V.92 protocol needs to be disabled.
The V.92 protocol must be disabled when using these modems with older modems. To disable the V.92 protocol on a USRobotics 5686 series modems, enter the following setup string (without the quotation marks), in addition to any string specified in the referenced bulletin, before saving the settings: " AT +PIG=1 +PMH=1 +PQC=3 ".
Refer to Bulletin 00-19
  • TAC IA Series
  • 2646
