Setting up Java Debug Tools
  • Setting up Java Debug Tools
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 11:40 AM
Various webstation or TGML issues
StruxureWare Web Station
Vista Web Station
Java script may be causing problems with Webstation.
How to turn on Java Debugging:
  1. Open Control Panel
  2. Select Java
  3. Chose the advanced tab
  4. Expand Debugging and check all boxes
  5. Expand Java console and select Show console
  6. When future errors occur you can capture the errors from the java console
  7. If you do not wish to have the console pop up, you can change the Java console back to Hide console and access the logs at this location:  C:\Users\CURRENTUSER\AppData\LocalLow\Sun\Java\Deployment\log
Labels (2)
  • 11125
