Setting the Infinet ID of an Infinet device to zero using RoamIO
  • Setting the Infinet ID of an Infinet device to zero using RoamIO
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2020-04-14 08:12 AM
on ‎2020-04-14 08:12 AM
How to use RoamIO to set the Infinet ID of Infinet device to zero before re-deploying the device.
Andover Continuum, EcoStruxure Building Operation
Continuum Service Tool
Need a way to set the Infinet ID of Infinet device to zero before re-deploying the device.
 This video demonstrates…
  • Tell if the i2 device has an Infinet ID assigned by observing the TD/RD LEDs on the device.
  • Use the RoamIO to connect directly to the i2 device and reset its Infinet ID to zero.
  • Confirm by visual observation of the device's TD/RD LEDs that the ID has been successfully set to zero.
Labels (2)
Tags (12)
  • AbeMeran20
  • continuum
  • ebo
  • Field Technician
  • i2
  • id
  • infinet
  • InfinetID
  • intermediate
  • roamio
  • RoamIO2
  • zero
100% helpful (7/7)
