Setting a Xenta 102-AX back to Factory Default Values
  • Setting a Xenta 102-AX back to Factory Default Values
  • Sacco
    Sacco
‎2018-09-06 01:11 PM
How to set a Xenta 102-AX back to factory default values.
  • Xenta 102-AX
  • Vista
  • LonMaker
  • NL220
  • Factory Default
Unwanted changes can be reset back to factory values.
To reset a Xenta 102-AX back to factory defaults, recommission the device and select Source of CP Values to default.
  • 6470
