Set up a two wire LTS80 Lini-Temp sensor on a 7740 and 7741 DCU
  • Set up a two wire LTS80 Lini-Temp sensor on a 7740 and 7741 DCU
‎2018-09-06 10:54 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:59 AM
Set up a two wire LTS80 Lini-Temp sensor on a 7740 and 7741 DCU.
  • 7740 DCU
  • 7741 DCU
  • LTS80 Lini-Temp sensor
Conversion coefficients must be set properly for correct reading of temperatures.
For Fahrenheit:
  • M = 0.17582
  • B = -279.4
For Centigrade:
  • M= 0.09768
  • B = -173.0
Refer to TCON 097 for 10K resistor placement
  • TAC INET
  • 1096
