Set up a two wire LTS80 Lini-Temp sensor on a 7728 PCU
  • Set up a two wire LTS80 Lini-Temp sensor on a 7728 PCU
‎2018-09-06 10:59 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:59 AM
Set up a two-wire LTS80 Lini-Temp sensor on a 7728 PCU
TAC INET
  • LTS80 Lini-Temp temperature sensor
  • 7728 PCU
Lini-temp is a type of temperature sensor that is compatible with the I/NET product line.
  • For Fahrenheit:
    • m = 0.21978
    • b = -459.6
  • For Centigrade:
    • m= 0.1221
    • b = -273.0
  • 10k ohm resistor in slot "A"
  • Refer to TCON 114: Model 7728 Series I/SITE I/O Controllers Installation Guide for details.
  • TAC INET
Tags (2)
  • 1099
  • RobertAndriolo24
