Set up a two wire LTS80 Lini-Temp sensor on a 7716 PCU
  • Set up a two wire LTS80 Lini-Temp sensor on a 7716 PCU
‎2018-09-06 10:55 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:58 AM
Set up a two-wire LTS80 Lini-Temp sensor on a 7716 PCU
TAC INET
  • LTS80 Lini-Temp temperature sensor
  • 7716 PCU
Lini-temp is a type of temperature sensor that is compatible with the I/NET product line.
  • For Fahrenheit:
    • m = 0.21978
    • b = -459.6
  • For Centigrade:
    • m = 0.1221
    • b = -273.0
  • J22 to 15 VDC
  • 10k ohm resistor in slot "A"
  • Refer to TCON 096: 7716 PCU Installation Guide for details
  • TAC INET
Tags (2)
  • 1097
  • RobertAndriolo24
