Set up a two wire LTS80 Lini-Temp sensor on a 7700 DCU
  • Set up a two wire LTS80 Lini-Temp sensor on a 7700 DCU
‎2018-09-06 10:52 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:58 AM
Set up a two-wire LTS80 Lini-Temp sensor on a 7700 DCU
TAC INET
  • 7700 DCU
  • LTS80 Lini-Temp sensor
Conversion coefficients must be set to read temperatures properly.
For Fahrenheit:
  • M = 0.17582
  • B = -279.4
For Centigrade:
  • M= 0.09768
  • B = -173.0
Refer to TCON 095 for Resistor(s) 41-55 to clip (suggest you clip only one side)
  • TAC INET
Tags (2)
  • 1095
  • RobertAndriolo24
