Set the Peripherals section of the Configuration Profile in I/NET Seven for Access Control
  • Set the Peripherals section of the Configuration Profile in I/NET Seven for Access Control
  • sesa139513
    sesa139513
‎2018-09-06 03:24 PM
How should I set the Peripherals section of the Configuration Profile in I/NET Seven for Access Control? I am not using I/DISKs; and I do not have any access control hardware on these comm ports.
I/NET Site
Leave the ports at the default settings. Make sure you enable the Access Control option in the Workstation Options of the configuration profile.
  • TAC INET
  • 1218
