Service pin a Loytec L-IP
  • Service pin a Loytec L-IP
  • SESA116857
    SESA116857
‎2018-09-06 03:06 PM
How to service pin a Loytec L-IP.
Loytec L-IP
Commission a Loytec L-IP into a LNS network.
The Loytec L-IP can be service pinned in one of two ways:
  1. If you have direct access to the router, press the status button to initiate a service pin.
  2. If you do not have direct access to the router, connect to the router via Ethernet to initiate a service pin. By entering the IP address of the router in a web browser you will reach the L-IP Device Info which has a button to send a service pin message.
  • 1988
