Sensors without using pockets, for Kamstrup meters
  • Sensors without using pockets, for Kamstrup meters
  • SESA150559
    SESA150559
‎2018-09-06 10:19 AM
Which sensors can be used if mounted directly into the pipe, without pockets?
Kamstrup heat cool flow meters
In some applications, sensors mounted directly into the pipe, without using pocket, is requested.
Unfortunately, we do only recommend the sensors that are included with the meter package, or ordered as an option with longer cords. All are requiring pockets for proper mounting.
  • Field Devices
  • 13542
