Sensor pockets for Kamstrup Heat / Flow meters
  • Sensor pockets for Kamstrup Heat / Flow meters
  • SESA150559
    SESA150559
‎2018-09-06 10:23 AM
Which pockets are included with the different size meters?
Kamstrup
Heat meter
Flow meter
Different applications requires different sensor pockets.
65mm pockets included up to DN20, 90mm pockets between DN25-DN80, 140mm pockets from DN100 and up.
  • Field Devices
  • 13301
