Sensitivity/accuracy of SPD310 sensor
  • Sensitivity/accuracy of SPD310 sensor
  • SESA150559
    SESA150559
‎2018-09-06 12:43 PM
Is the SPD310 sensor accurate all the way down to 0 Pa?
SPD sensor
Application on lower measurement levels.
The sensor will not be accurate all the way down to zero. Select a sensor that is mid-range for the measurement being made.
  • Field Devices
  • 7249
