Sending Secure email to SMTP host from Tridium Jaces
  • Sending Secure email to SMTP host from Tridium Jaces
  • RandyDavis
    RandyDavis
Guinan RandyDavis Guinan
‎2020-03-04 01:04 PM
on ‎2020-03-04 01:04 PM
How do I configure outbound email to satisfy a hosting service that requires SSL/TLS
TAC IA Series
  • ENC-410
  • ENC-520
  • JACE-2
Many SMTP(email) host no longer except non-secure email for transmission.  They require, at minimum, SSLv3 inbound messages.
The devices mentioned in the "Environment" section all use the IBM J9 Java Virtual Machine and can not be configured for the minimum secure socket the hosts require.  You must upgrade this hardware if you want to use one of these secure SMTP Host providers. If you are unsure of the JVM on the device, look at the Platform of the device.; The Jace 6E/645 and the Jace 8000 use the Oracle-Sun HotSpot JVM and meet the requirements.
ENC 520 (J404) unsupported SSL/TLS
Jace 6E-645 Supported TLS using the Oracle-Sun Hotspot JVM
Jace 8000 Supported TLS using the Oracle-Sun Hotspot JVM
  • TAC IA Series
Tags (9)
  • email
  • ENC 645
  • enc-520
  • Jace 6E
  • Jace 8000
  • RandyDavis20
  • smtp
  • ssl
  • tls
50% helpful (1/2)
