Sending BACnet alarms to a third party BACnet device (from bCX or b3 controller)
  • Sending BACnet alarms to a third party BACnet device (from bCX or b3 controller)
  • PaulFr
    PaulFr
  • Dave_Shore
    Dave_Shore
‎2018-09-11 03:55 AM
Continuum BACnet
Cyberstation, B-OWS
Clarification required on the best way to send BACnet alarms to a third party BACnet device (from bCX or b3 controller).
There are two main methods that can be used. The Event Notification Delivery tab should be set up using the Continuum discovered BACnet address or the NET:MAC method see below.
Both methods generate the same packet and should give the same results.
It is normally recommended to use Guarantee Delivery
Method 1
Method 2
NOTE
BACnet Global Broadcast is not often used
  • 13317
