Security Requirements for the SQL sa password
  • Security Requirements for the SQL sa password
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 01:27 PM
Changed sa user name as requested and unable to log in to DbCreate using that username
Unable to use standard "sa" password for "sa" username
  • DbCreate
  • I/NET Seven
  • SQL
Due to new security requirements from Windows and SQL you are unable to leave the SQL admin password as the default: Username: "sa" and Password : "sa".  When installing I/NET you will be asked to provide a new more secure password.
The "sa" username cannot and should not be changed.
  1. When installing I/NET have a new username for SQL ready.  This must be something that can be recorded and available to technician when needed
  2. When prompted, enter the new password.  You will have to enter in twice to verify the text
  3. To run DbCreate us the username: "sa" and the password that you entered during installation.
  • TAC INET
  • 5859
