Security Expert: Updating site: Preferred order of installation
  • Security Expert: Updating site: Preferred order of installation
Lieutenant JG JamesMorgan Lieutenant JG
‎2022-12-13 08:52 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:33 AM
What is the best order to update software and firmware from very outdated sites? Should we update the controller's firmware or Security Expert client/Server software first?
EcoStruxure Security Expert
Security Expert Controller
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Controller, firmware, Client, Server, Software
  1. Update the controller's OS to 2.0.27
  2. Then update the controller's firmware to the "interim-build" v2.08.1287
  3. Then update to release build 2.08.1295.
    Firmware is located on the EcoExpert Extranet
There is no importance of installation order between controller firmware and Client/Server software
  • EcoStruxure Security Expert
  • JamesMorgan22
