Security Expert Reader SX-RK-XW usage with Continuum
  • Security Expert Reader SX-RK-XW usage with Continuum
  • Alan_Wood
    Alan_Wood
Admiral Alan_Wood Admiral
‎2024-10-10 12:07 PM
on ‎2024-10-10 12:07 PM
Using a Security Expert SX-RK-XW reader to work with Continuum
Andover Continuum
  • Continuum 2.03
  • ACX 5740
  • CX9702
It can be useful prior to a transition from Continuum to Security Expert to use Security Expert readers with Continuum
Minimal functionality testing was done using the Security Expert reader model SX-RK-XW
Continuum 2.03
ACX5740 with firmware: 1.100013 and 1.100052
CX9702 with firmware: 1.200036
Tested with Pin Only mode by setting up a door, a card holder and entering in the appropriate PIN code
5740 with SX Reader
ACX 5740 PIN Only Active Event View
CX 9702 with SX Reader
CX 9702 PIN Only Active Event View
  • AlanWood24
