Security Expert - Denied Entry by "Entry Mode Error Door Waiting for Bio Mode Card Input Credentials"
  • Security Expert - Denied Entry by "Entry Mode Error Door Waiting for Bio Mode Card Input Credentials"
  • GavinHe
    GavinHe
Sisko GavinHe Sisko
‎2023-09-10 07:10 PM
on ‎2023-09-10 07:10 PM
Security Expert is denying user entry to a door and generating an event message stating waiting for Bio Mode Card Input Credentials.  Biometric credentials are not being used for the door.
EcoStruxure Security Expert
Security Expert Client
Custom credential settings are not correctly configured for the door and reader.  The door is set to use a Door Type expecting a Custom Credential but the Reader is configured to use a standard card format.
To fix the issue the Reader must also be configured to use a Custom Credential.
  1. Navigate to Reader Expanders and select the associated Reader Expander.
  2. For the Reader set the Reader(x) Format to Custom Credential as expected in the Door Type
  3. Right click the Reader Expander, select Update Module, and after a successful update test the operation.04 - Module Update.png
  • EcoStruxure Security Expert
  • GavinHeward23
