Security Expert Controller: supported USB adaptors
  • Security Expert Controller: supported USB adaptors
Lieutenant JG JamesMorgan Lieutenant JG
‎2023-12-13 01:32 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:32 AM
What are the supported USB Adaptors for SP-C?
Security Expert
Security Expert Controller (With USB Port)
The USB port on the SP-C supports USB to ethernet adaptors. It MUST have the following chipset ID: ASIX - AX88772C
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
  • EcoStruxure Security Expert
  • JamesMorgan23
