Security Expert 37-Bit Reader Format in Security Expert
  • Security Expert 37-Bit Reader Format in Security Expert
  • David_Kendrick
    David_Kendrick
  • DavidChild
    DavidChild
Admiral David_Kendrick Admiral
‎2021-04-13 08:02 AM
Last Updated: Sisko DavidChild Sisko ‎2022-04-22 12:45 AM
There is a Security Expert 37-Bit Reader Format in the Security Expert system
(formerly Schneider Electric 37-Bit)
Security Expert
Reader Formats
Is the Security Expert 37-Bit Reader Format in Security Expert the same as the Infinity 37-Bit Wiegand Format used in Continuum and if so, can this be selected for transitioning systems?
The Security Expert 37-Bit Reader Format in the Security Expert system is not the same as the Infinity 37-Bit Wiegand Format used in Continuum.  Infinity 37-Bit cards transitioning to a Security Expert system will need to be accommodated using either Custom Formats or Custom Credentials.
  • EcoStruxure Security Expert
Tags (2)
  • DavidKendrick21
  • DavidKendrick22
0% helpful (0/1)
