Second door reader (09 Door) does not work on 7920 controller
  • Second door reader (09 Door) does not work on 7920 controller
‎2018-09-06 03:22 PM
7920 DPU
If you have defined one door in a DPU-7920, and the door's exit reader parameter is set to anything besides NO, then the second reader port automatically becomes the exit reader.
If you have defined two doors in a DPU 7920, neither door can have an exit reader defined. Set the door's exit reader parameter to NO.
  • TAC INET
  • 1272
