Saving Customized Detail Windows in Vista
  • Saving Customized Detail Windows in Vista
  • SESA116857
    SESA116857
‎2018-09-06 03:11 PM
TAC Vista Workstation
Every time you close the Details window the customized settings of that window are lost.
To save these customized settings:
  1. Set up Vista with the customized Details window as you wish.
  2. Use the File > Save My Program Settings command (Ctrl-S) which will save the settings
  3. Recover them at any time through the use of the File > Load My Program Settings command
This method will work with multiple Details windows with individually customized settings as well.
  • 1762
