Satchwell MicroNet Touchscreen or LCD with 24VDC MicroNet 50 series controllers
  • Satchwell MicroNet Touchscreen or LCD with 24VDC MicroNet 50 series controllers
  • CraigEl
    CraigEl
Gary Schneider Alumni (Retired)
‎2019-08-27 06:09 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-06 04:26 PM
When using the ribbon cable provided with Satchwell MicroNet Touchscreens or LCDs to supply power from a MicroNet 50 series controller powered by 24VDC, the display units may not function correctly due to hardware incompatibility.
Satchwell MicroNet
  • Satchwell MicroNet Touchscreens
  • Satchwell MicroNet LCDs
  • Satchwell MicroNet 50 series controllers
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
  • The MicroNet 50 Series controllers support both 24VAC and 24VDC input.
  • The Touchscreen and LCD displays are adapted from MicroNet 100 Series hardware, which does not support 24VDC power input.
  • Using the ribbon cable to supply 24VDC from the controller to the display can result in malfunction or damage.
⚠️ Important Notices
  • The MicroNet 50 series controllers (MN350, MN450, MN550, MN650 LCD and Touchscreen) have been withdrawn from sale.
  • The IAC 420, IAC 600, and Touchscreen models have also been discontinued.
  • No direct replacements are currently offered.
For more details, refer to:
  • PA-00495 - Notice of Withdrawal - Satchwell Sigma (PDF)
  • PA-00528 - End of Commercialization - Satchwell Sigma (PDF)
  • Do not use the ribbon cable to power the display from a 24VDC-powered controller.
  • Instead, use a separate 24VAC transformer to power the Touchscreen or LCD.
Tags (3)
  • CraigEllis25
  • GaryMontague19
  • GaryMontague21
